Trying to install FM modulator for S50 in my Lincoln | SatelliteGuys.US
dee8go
4
I could not find a thread that addressed this issue. I'm trying to install the FM modulator for my Sirius S 50 in my 1998 Lincoln Continental. Apparently the reciever is in the trunk, so I have to run cable from the S 50 back to the trunk. I can't figure out what to connect the antenna end of this cable to. There were no instructions of any kind.
I hate to send members elsewhere, but go check over at siriusbackstage.com. You will have a better chance of finding what youre looking for.
The fm modulator goes into the radio where the antenna plugs in and the antenna plugs into the FM Modulator. Since it's a Ford you may need antenna adapters as some Ford models used non standard antenna adapters.
The easiest way if you can is to follow the antenna cable to where it enters the radio.
SIRIUS Coverage in Canada
talk radio and the newsgroups
