true newbie | SatelliteGuys.US
true newbie
icu1954
275
lower alabama
hi,still waiting on my equipment,i wanted to know if i needed to buy the coax cable with the ground wire that's built in with the coax cable,this is the cable that will run from the dish to the receiver,also i have bought a install kit for dss satellite that have everything from grounding block,straps etc. will this be a good choice,also could i just couple in to my existing dish network cableling.If i sound like i know nothing,then you are right,that's why i need you guys...this is a great site...please bear with me..thanks
couple of thoughts
1. If starting a new topic please use a better title than "help" or "newbie". Makes it easier to know what you're asking
2. I have merged all your other posts into one big thread here http://www.satelliteguys.us/free-air-fta-discussion/226229-true-newbie.html
please use that with your install and questions until you're up and running
The above post is copied into your other thread
Cannot figure out FTA receiver
DVB DISEQC 1.2 DTB
