Total NOOB with an Openbox S10 and questions | SatelliteGuys.US
CacheFreeTV
48
Utah
Hi, gang. Total noob to FTA, and I have some total noob FTA questions...
I have an Openbox S10, new and never used, and am planning to get a 3-foot dish later this year, and motorizing it soon after. In the meantime, I have an old DirecTV "slimline" dish, 22x32, that I'd like to play with. The math says it's equivalent to a 27" circular dish. I've mounted a linear LNB on it and would like your opinions on my chances for Galaxy 19 - specifically, The Filipino Channel:
TFC North America West 18 4399 4400 Tag
My location: Utah
Latitude Longitude
41. -111.
Any opinions? (The wife will give her blessing to money for a huge dish if I can get it for free!)
And now, about the Openbox S10... I know there are a few mods I might have to do to it (thanks, Pixl and others!) Thats no biggie, I'm an electronics tech. My question is, what is your preferred firmware for the S10?
thanks for any help and opinions.
Think many are running this: http://www.satelliteguys.us/downloads.php?do=file&id=296
So backup your current firmware before loading this.
I'm using it on my S9 and it's the best so far. (So far??, I'm done trying firmware for two reasons. This one works and don't think there's any ongoing development, from the MFG or third parties)
Your slimline should get many stations on 97W. I have a commercial 30 inch and it doesn't miss a thing there.
... I have an old DirecTV "slimline" dish, 22x32, that I'd like to play with. The math says it's equivalent to a 27" circular dish. I've mounted a linear LNB on it ...
Actually, unless your linear LNBF has a feedhorn that "sees" the whole oval of your Slimline, it probably is closer in equivalence to a 22" (the height of your Slimline) circular dish. Most likely, your LNBF "sees" a circle, not an oval.
That being said, I also have tested a common linear LNBF on a Slimline, and got all but the weakest tps on 97W...good luck, it's well worth a try.
It was a bear to find, but I located your Slimline thread http://www.satelliteguys.us/showthread.php?t=228019 and it looks do-able.
I was wondering - do you know where I could find an LNB that could see the whole dish?
Think many are running this: http://www.satelliteguys.us/downloads.php?do=file&id=296So backup your current firmware before loading this.
Thanks for your help, much appreciated!
Galaxy 19 (97W) Ku-band channel guide -- March 6 update
How many Remotes do you have on your coffee table
