Top 180 pack only requires 61.5? | Page 2 | SatelliteGuys.US
Iceberg said:
you will need a Superdish for the locals, so now you're looking at 105, 110 & 119
The reason I didnt say anything about CBS-HD is you have to qualify for it and only 35% of the people can
Your CBS has to be owned and operated by the network to get CBS-HD or be in a white area, which as a new customer is pretty much long gone
I believe you can also qualify (per the SHVERA) if you have waivers.
Tonner said:
I have 2 811's and I was hoping to get 61.5 on both 811 receivers. can I send the other LNB on the dish 500 to another receivers via another DP21?
So total I have a superdish with 3 LNB's feeding all three to dish ports on the first DP34 switch. Then I hang a second DP34 and feed the 2 811's from two DP21's which are connected to the new DP34 switch ports. Is this possible?
Yes. You've got it.
Top 180-pentagon channel?
Legacy setup and 921/942
