This Tv, METV on AMC 1 103 | Page 2 | SatelliteGuys.US
Working here from a previous scan: AMC 1 at 103w @ 3740 V 29270
ME 1, V 2260, A 2220Dolby D, P 2260
Me 2, V 2360, A 2320Dolby D, P 2360
This, V 2160, A 2120Dolby D, P 2160
And a TP scan still doesn't find them but finds the other 3. S9 receiver used.
The newer Ali editor worked to enable AC3 sound. It was not an option in the older PVR800 editor.
I also learned the Ali editors will only work with an openbox image file - .ABS
They will not do business with the transponder/channel list file - .DBS that can be saved to USB stickunder the MISC FILES option in the openbox onscreen menu system. That gave me some trouble until I figured it out.
Now watching ThisTV with AC3 sound again.
Thanks carlospr43.
But you can just rename the .dbs file to .abs and edit. Before transferring the edited .abs file back to the Openbox, rename it .dbs.
Thanks carlospr43.
:up:up
you do realize both of these are on 87W right?
I know 87W doesnt reach Puerto Rico where Carlos is but if you're in the states 87W works just fine and is easier to grab than 103
ME TV and This TV are also currently on SES 1.
3984 V 2734 This TV
4014 V 5924 ME TV 1 and ME TV 2
I'm using a C-band dish in fixed position with 3 LNBs. I'm currently setup on 91, 99, and 103. There are other channels on 103w we didn't want to lose.
MeTV and ThisTV coming to KU Band this week!! (eh maybe not)
Many RTV and other channels recently added to 137W?
