This forum Doesn't stay logged in | SatelliteGuys.US
Not open for further replies.
Yes I check "remember me" when I log in. Anyone else having this problem?
I started having this problem about a week ago and nothing has changed on my setting and my cookies is not blocked :)
Its a bad cookie stored on your PC.
Delete all your SatelliteGuys cookies, restart your browser, and login and again and you will be all set.
Thanks Scott appreciate it and I will try that and I close browser and clean everything out every night before I go to bed and restart it when I get up in morning :) Have question what is satellite cookies? Is it same as my other cookies and if so thanks and if not how do I delete SatelliteGuys cookies? Thank you very much for all your help appreciate it :)
cookie.jpg ;):D
the tracking cookies specifically for this site
I know on firefox I can remove cookies for specific sites instead of all. There is only 5 or 6 sites that I have a login/password saved so I can remove all cookies but those few sites
Thanks ice I appreciate it I am on IE on my laptop and how you do that on this site and with the tracking cookies on this site? Thanks again :)
not a clue. All I can see is how to remove all the cookies
Ok! How you do that?That may help with it here and maybe figure it out with what is going on here and thanks for your help appreciate it :)
I had to open internet explorer to check because I use Firefox, but depending on your version it should be Options, the general tab, then browsing history section, delete, a list should come up one of which is cookies, check it, and pick delete. Work your way out, then close internet explorer, and reopen. I don't see a way to delete individual cookies, but I didn't take time to really find it.
Thank you very much i appreciate it I will try it :)
Home Theater Cruise Forum
Home page issue
