Yes I check "remember me" when I log in. Anyone else having this problem?
Its a bad cookie stored on your PC.
Delete all your SatelliteGuys cookies, restart your browser, and login and again and you will be all set.
the tracking cookies specifically for this siteThanks Scott appreciate it and I will try that and I close browser and clean everything out every night before I go to bed and restart it when I get up in morningHave question what is satellite cookies? Is it same as my other cookies and if so thanks and if not how do I delete SatelliteGuys cookies? Thank you very much for all your help appreciate it
I know on firefox I can remove cookies for specific sites instead of all. There is only 5 or 6 sites that I have a login/password saved so I can remove all cookies but those few sites
not a clue. All I can see is how to remove all the cookies
I had to open internet explorer to check because I use Firefox, but depending on your version it should be Options, the general tab, then browsing history section, delete, a list should come up one of which is cookies, check it, and pick delete. Work your way out, then close internet explorer, and reopen. I don't see a way to delete individual cookies, but I didn't take time to really find it.
Limited time offer
