It depends on how your monitor is set up.dont24 said:Not sure if this has been discussed. Is it just me, or is the score in the upper left corner cut off? Can't see the "B" or "R". I've noticed this before, but never gave it much thought.
I only have this problem on the Mits downstairs in the HT Room, but it's not enough to worry about.RandallA said:It's been mentioned before, I think the score is way to the left and it doesn't show completely in most monitors.
Thanks. Certainly nothing to worry about. Just wanted to make sure I wasn't the only one.riffjim4069 said:I only have this problem on the Mits downstairs in the HT Room, but it's not enough to worry about.
In the Camp Nou they are always this side. In the Bernabeu they are opposite looking into the technical arearoachxp said:I just noticed aren't the WorldsportHD cameras usaully on the opposite side of the field.
HT
Limited time offer
