Telstar 6 Outage | SatelliteGuys.US
Telstar 6 Outage
PKII
791
19
WV
Anyone having problems on Telstar 6 C band? I can't get no feeds to come thru clearly. The scrambled channels that are normally there are gone? Anyone have any info on this?
can you still get PBS on Channel 8?
I dont think that has been turned off yet (PBS moved to AMC4 TP16 and mirrored on T6 TP8 for 2 months)
I get IA-6 fine. Are you sure you are at the right loaction. Go to G-11 transponder10, the shopping channels should be there. Then bump it to the west until you see PBS. Its on transponder 8 so you will have to turn the channel to 8 before bumping the dish west.
Yes. On C band. I can get that channel. 8, 16, 22, 24 are on now. Scrambled channels on 1, 7 are still off. Does that happen occassionally? earlier none of the channels were on.
voomvoom said:
They are on here. Maybe your polarotor quit working?
Al
hmm. Just noticed those are all even numbers. lol. I think your right. :) Thanks.
Wideband Feedhorn install how to
Actuator Motor Voltage
