TechSAT TRACKER II | Page 3 | SatelliteGuys.US
TechSAT TRACKER II
It does get improvement when I turn it to the right and a bit up... Even I had to my hold the dish and I unscrew the bolts and I screwed the bolts but went to same status.. I'll find a way.
Friends.... Last night I tried to to improve the Q but I couldn't get it more then 55% I guess I have some trees and that would be the best Q signal for my house.
The Skytracker sure helps you because it tells you if your hitting a satellite which goes for Galaxy 25 it showed 83.9% and I had to make a left and right movement and I got the quailty. you dont have to look at the tv and plus I dont like the Traxis system because its not easy to find the Q signal on the box. until you 100% sure. With the Skytracker every move on the dish it keeps weaker or stronger tone with % of contact with a Satellite.
Problem Finding Birds
I Have A Problem
