77-78
Hmmm, you should have your locals in HD if you have a signal that strong.
They are lower than you would like, but you should still have a picture if your signal is that strong.
77-78
I may have just answered the last question about slimline 3. I guess if it is only showing 99-101-103, that means it is a 3 lnb.
Yes I did do repeat satellite setup. I could do it again I suppose if you think it would help. That was where I confirmed it was still set with my slimline and multi-switch and kept hitting continue.
Uh oh, "I'm kinda at a loss" sounds like you're giving up. Don't give up!!! Never say die. I am guessing you are an installer. Call a comrad and see if they have ideas. I'm gonna re-run setup now. Should I do it with it set first to show all channels or will it not matter?
Well I repeated satellite setup. No go. I then hit the reset button to no avail. Man this blows!!!!
Limited time offer
