Switch Recommendation | SatelliteGuys.US
quicksand2006
19
I need to buy a new DiSEqC switch. Anyone have any suggestions as to which brand I should buy.......I have read about the Chieta and it sounds like the one I am leaning towards.....CHIETA 4x1 DiSEqc WSD-2041 (Heavy Duty). Any comments suggestions....pros and cons would be appreciated......
Cons : As with all switch make sure to POWER DOWN completely before connecting or disconnecting any switches!
As far as a "budget" switch goes I really like Chieta. You cant beat it for the price you pay. If you want a quality switch check out Spaun but be prepared to pay big bucks for it.
They range in price from 5$ to 15$ on ebay. There pretty much all the same to me. I fried a good digiwave and fortec switch, then bought a no-name, and its has been working for 6mo no problem. So price point wise.....hey its not a huge purchase, I would suggest go cheap.
Directv and Telstar 5?
Hindi Channels on Telstar 5???
