SW 21 | SatelliteGuys.US
SW 21
A SW21 switch is designed to give access to 2 satellites but DISH dosen't run a SW21 into other switches. Other switches are run into one leg of a SW21 and is only for LEGACY equipment.
i have heard that you can have a Dpp44 and Dp21 used together to get 5 sats on a single tuner, but i forget which order they were set-up. i am pretty sure it was on another topic here on this forum
output from dpp44 to one side of DP21, 5th satellite to the other side, output to tuner. Good luck with that.
HDNet show looks better on DishOnline than satellite!
LNB question
