SV8000HD Hiccups on DTV | SatelliteGuys.US
JohninSD
84
8
San Diego
:confused:
Having a peculiar problem with my Sonicview 8000HD while watching OTA channels. It will occasionally "hiccup", losing picture and sound for a second or so, flashing the channel display along the bottom of the screen, then resuming normal operation. I'm running FW version 4.43 and have replaced the problematic capacitors in the PS. It doesn't do this when I'm watching FTA channels, only OTA. Anyone else seen this behavior?
thanks,
John
Signal's fine - 100% Q on most channels. No glitches when I use my converter boxes, just when I use the Sonicview.
Sv8000
To fix problems on my sv8000 used the clean bin and reloaded channel list I had saved. Dish net has figured out how to corrupt receiver if you visited their birds. I stay away from them now with the SV.:rolleyes:
trouble locking satellite signals
Boxing up dishes.
