SuperDish for 129? | SatelliteGuys.US
SuperDish for 129?
OrangeandBlue33
102
12
I'm looking to upgrade soon to HD and wanted to know if the SuperDish I already have could be used to pull in 129 for the HD content?
Just for kicks, I did a signal strength test from my current receiver and I was picking up a fairly strong signal on 129. On one of the transponders I even had a signal strength of 75.
Would E* replace the dish with another, or will they use the same one I currently have?
Thanks for any feedback!
129 repoint kit
Dish actually makes a kit for this very thing - comes with a new arm, yoke to hold 3 dp duals. It works great for me - the superdish pulls in a way better signal on 129 than a 1000.2 dish. Anytime I roll up on a HD upgrade and they have a superdish I am looking to use this kit.
I have to modify the work order everytime, but in my opinion, it's worth the hassle. Your installer would need a 129 repoint kit and two dp duals - you have one on your superdish.
use the SuperDish, you won't be disappointed....used it at my parents house and picks up MUCH better than a 1000 ever could
Cool. You guys have made my day. When I call for an upgrade what are the chances a CSR will be able to sort this out? Do I ask for Tech Support? What's the best route to take?
Thanks Ftoutloff and daboogas94e!
Question...
How are you currently getting the 129 at your home?
Question...
I have a SuperDish that was originally set up for my locals on, I believe, 121. It's currently picking up 110/119. As I said, I just thought I'd check to see If I was picking anything up from the 129 transponders - and it appears that I am. Does that make sense?
added: - The signal's not "locking in", but it is showing on the meter, so I assumed it must be at least seeing 129 somehow.
Then that is in error. If it's locked in, then yes...you are receiving it.
My issue would be the additional lines/cables needed for your HD upgrade. Unless you already have everything ran, your installer will probably be tempted to just give you a D1000.2. The DPP technology will save from having to run two lines for a dual tuner.
So what signal is the receiver seeing when I've selected 129, Transponder xx? My knowledge is pretty low on this stuff. I know just enough to be dangerous.
So if I'm understanding you correctly, as far as the DPP technology, - it would allow for 1 cable run of RG6 for the HD dual tuner? Whereas with my current set-up I'd have to run 2? I do currently have two lines run for 2 separate receivers, but I was considering keeping one of them to have as extra.
If it's a matter of running another line, that's not that big of a deal for me to do as I purchased, installed and set-up all of my original Dish equipment 10 years ago - including the cable run and dish alignment etc....
I guess I'd prefer to keep the dish that's already there if it's going to give me a better chance of pulling in a better signal.
Anymore info would be greatly appreciated.
Where else can I sell this?
Chiller Channel At 5:00pm Today
