Super Dish/Locals | SatelliteGuys.US
Super Dish/Locals
btb79
I am in the process of moving and will be using DISH Mover to install service at our new house. E* CSR told me to take receivers with me and just leave the dish. I called them back later and asked them what happens to the dish?, do they come and get it? and they said no. So I asked if I can take the dish down it keep it for myself and they said yes.
1. Is this right that I basically own the Super Dish and I can do whatever I want with it?
2. The reason I have the Super Dish is to get local channels for La Crosse, WI. If I give the Super Dish to my father to use when he's camping with say a 311 receiver, will he be able to view the La Crosse locals while camping?
3. Any suggestions for my father on a tripod and mounting system for mounting the Super Dish while camping?
Thanks!
1. Yes
2. Only if where he is camping is still within that spot beam. If he goes states away to camp then no.
3. May I suggest to not bother the Superdish is not real easy to aim.
Superdish locals are CONUS so the spotbeam is irrelevant
make sure you arent leasing, because they'll want the LNB back for the SD
110 Dish settings
Dolby 5.1 Programming
