STREAMING from AZBox > PC | Page 3 | SatelliteGuys.US
The distance would depend on the Wireless Router model you pick, firmware you use with it (consider DD-WRT) and RF noise level in your area. You can connect your own Antenna to a wireless router instead of its original one that can sharply extend the distance. People reported getting Wi-Fi high speed internet access over large distances with good antennas on both ends.
I asked about saving a streamed by AZBox signal on a PC, since the same trick can possibly be used with OpenBox to save and play 4:2:2 channels on PC, since OpenBox is also Linux based STB.
How Do You Rename A Satellite On AZbox Premium Plus?
Azbox Enigma2 remote control mapping
