stb problem - anyone else? Yes, don't reboot if you don't have to | Page 6 | SatelliteGuys.US
It's really too bad some peoples rec's are not booting up now that the fix is in. It sounds like some units were corrupted. Mine seem to be just fine now. I've only had one lockup on one of the rec's since last night.
One last thing that you can try is to remove & reinsert the access card while it is in standby. Or just unplugged. For those that don't know where it is. It is located just to the right of the front panal buttons behind a small hatch. If you look closely you will see the cut out of it. Push the upper right corner of it. It should pop out on the top & then just swing it down.
If your Billing is incorrect, You need to do the following...
Who has gotten red light dead box fix?
