starchoice and nfl network channel 420 | Page 2 | SatelliteGuys.US
uh oh
might be the LNB then. If its on both receivers, then a rehit won't do it. Doesnt sound like the dish needs a repoint since the F1 signals are good.
okay bypassing zinwell 4*8 seems to work nfl net crystal clear
the zinwell ssam4803 is hot cant hold hand on it for 10 sec without getting burned
switch is burned out let it cool down hooked backup nfl net still nogo
anyone know where i can get a cheap 4*8 not zinwell or shall i go the bay route?
Stone how many receivers do you have hooked up? If its less than 4, don't use a switch. The switch is built in to the LNB to switch between the two
Otherwise Ebay is the best. I got one cheap on there...brand new
Need help with skew
AMC coming to SC
