Spray Paint OTA Antenna? | SatelliteGuys.US
hypokondriak
21
In order to resolve my antenna problems (Winegard 4400) I had to mount it pretty high on the roof. Can I spray paint this sucker to help blend it in?
To me it would seem that a flat brownish / gray (blend in with roof & branches) would be much better than super shiny silver.
Will this cause any problems with reception? Any one recommend a better color to paint it?
I can't imagine a thin coat of paint causing any deterioration of signal. If I were going to do this I would make sure it would be a paint that would stick to the metal used in the antenna.
I've wondered if I could get away with twining some vines, probably plastic ones, around a rooftop antenna to make it less noticeable. Doubt that it would affect performance but would like to conceal it from the HOs association.
OTA Antenna Help
So does anyone know how this works in Denver DMA Fox
