Sound Volume | SatelliteGuys.US
Sound Volume
Tom_T
35
I have noticed that the sound is at a different volume depending which tuner. I swap back and forth quite a bit and this is a little annoying as I have to adjust the volumn each time.
Anyone experiencing this problem or have a suggestion on how to fix it.
This is a 922. :)
TIA
I have tried both ways and still the same. Just odd that the sound is louder on one tuner than the other.
thanks for the reply
Are you talking about on the same channel (including OTA vs satellite)? Or do you mean for different channels?
No same channel, I have tried several and it's the same. I use swap to watch different channels as it is faster and I can pause/ rewind etc. On my 622 the volume level is the same.
Notice on REELZ Channel
1080p PPV
