Very interesting, Cyberham. I had no idea. This is why I see American shows on CTV2. I just wish I could watch CBC.
This is really interesting, as the receiving surface is much smaller than surface of "pizza dish" (dia = 18" = appr. 45 cm). In our FAQ info, we got only info about 4 dish types: Primefocus, Offset, Gregorian and Cassegrain, would be nice to add some info about horn devices. Did you open this horn, just to see what is inside? You said there is Fresnel lens, I assume it is much thinner lens than a regular one. But you also mentioned that it is rather heavy. Is there any manufacturer's info about this horn, or, maybe, a Patent # on it? Cheers, polgyverAstra 1 cluster at 19.2e as it was designed for, but see no reason why it wouldn't work with other high powered satellites/clusters over Europe
30cm diameter
Fresenl Lens I believe is perspex.
Cheers
Thanks for the scan, some of its words helped me do more advanced Google search. So I found more tech. info. This antenna is presently not available (discontinued). By the way, I found something even more interesting, Product Review, it is antenna in the shape of a pipe. Unfortunately, also discontinued. So much about non-conventional receiving of satellite signals... Cheers, polgyverHi, no I've not had her open, I was planning to but when it was bought, found it had already been swapped by the previous owner to a dual universal flange LNB.
All I can provide really is a scan of the original manual. No patent info I can find.
>> Revox AS-2000 << That's one odd lookin' "dish" I remember, many years ago, of plans in one of the hobbyist magazines to construct a C band fresnel out of plywood and, at least, aluminum foil. Glad I didn't attempt. If I remember right, it was HUGH!
Limited time offer
