Slip/Skip Fast Forward | SatelliteGuys.US
tigerfan33
7,241
582
Alabama
Can the remote for the HR24 be set up to skip 30 seconds ahead instead of slip??
There was a way to set it up on my old remote for the HR21 but for got how. Not even sure if it possible with this remote.
Menu > Smart Search
Type 30skip
Highlight "30SKIP Keyword"
Press select
select all
You wont find anything but this should change it from slip to skip.
BTW, you aren't setting up the remote to perform the function, you are telling the DVR to respond differently to the button.
And 30SLIP returns it to slip mode.
Thanks guys!!
I should have told my installer about Satelliteguys. :)
No Signal
Forgot Parental Lockout Password on D-11 Receiver
