SL3 K4n hookup | SatelliteGuys.US
SL3 K4n hookup
johnnyrock
4
clifford, pa
New poster, upgrading to HD, Bought new dish off ebay .Have new hd20 recieverfrom direct tv.plan on running 2 recievers, new hd and old non hd. do i need 2 home runs and where do i connect at SL3 K4Nro-o2 lnb.I have installed old dishes this is my first install of hd Can someone hook a brother up?
:welcome to Satelliteguys!
Are you sure of that part number? I can't find it anywhere. What is the model number of the non hd receiver?
I'm assuming it's a slimline 3 LNB
That was my guess, but without being sure, I'll wait to answer his questions.
The D10 isn't that old, it's a Directv branded box. The only problem would have been if the lnb was a SWiM type. The D10 wouldn't work with it then. Just run two lines from the lnb into the house using one on each receiver. The dish install is basically the same as always, but it takes more careful aiming. If you need advice on that, come on back and ask!
No Plan to add TruTv Hd etc.
Internet on Whole Home system
