Since upgrade 622 screen will go blank but with sound | SatelliteGuys.US
johnch
SatelliteGuys Guru
Since 612 update I sometimes get a blank screen with sound. Sometimes if I wait long enough it will recover but it may take 10-15 minutes. The only solution is to do a hard reboot.
I have run a check switch and also have no errors on info screen. I was told by tech support that because I had a drifting lnb on 61.5 this would cause the problem. Well yesterday they replaced the lnb which fixed the drift but I still have this problem.
Any suggestions before I call Tech back?
JC
I had the same problem, called E* 3 times, no help, next time I called I told them that the HDMI output stopped working, they sent me another box, problem solved.
Controlling TV1 from Another Room
HDMI questions...
