Signal Strength - Newbie Question | SatelliteGuys.US
cprickett
51
Signal Quality - Newbie Question
I apologize if this is a repeat post. I did a search and spent about 2 hours trying to find the answer, but was unsuccessful.
I have a 522 and a 510. The signal quality in the setup screen on my 510 is 110 - 115. The quality on my 522 is 95-100. The RG6 run from the dish to the 510 is shorter than the run to the 522.
1. Is this the reason for the loss of signal quality to the 522 the length of the cable?
2. Or, is the DPP switch that used to split a single output into two for the 522 the reason?
3. Would I get a better signal quality if I re-run the feed to the 522 and use a shorter route?
4. Does any of this matter since I have signal quality between 95-100 on one receiver and above 100 on another?
Thanks for your help.
I have a 522 and a 510. The signal strength in the setup screen on my 510 is 110 - 115. The strength on my 522 is 95-100. The RG6 run from the dish to the 510 is shorter than the run to the 522.
1. Is this the reason for the loss of signal strength to the 522 the length of the cable?
3. Would I get a better signal strength if I re-run the feed to the 522 and use a shorter route?
4. Does any of this matter since I have signal strength between 95-100 on one receiver and above 100 on another?
I just had a 625/522 installed. The installer said to ad 15 to it's signal strength (nature of the beast). So you are right on. Relax and forget it.
The reading is signal quality, not strength. Very little relation to cable length or losses.
Reading is dif for dif receivers and range is set by internal software. I can remember when 80 was best you could do.
The dual tuners have a different software suite and report signal strength differently. I find it's usually about 10 down. So long as your signal on transponders 11 and 12 are both over 85 you'll have no problems.
Re-Peak Dish 500
? About switching 921 to 942
