shaw satelite Canada | SatelliteGuys.US
mjlafleur
25
alberta
I have a New directv dish on my house would it work for shaw Canadian satellite or do I have to change the LNB and the dish.
actually if your dish is a New Slimline dish it will work fine as long as you put a Shaw LNB on it. a 60E or 75E work perfectly fine on it. It is identical to the Shawdirect 75 cm dish, just made with metal instead of fiberglass and it has better fine tune adjustments.
You need to sign up for the Home Away From Home program. You will receive a 75 cm dish to take with you. Try to get one with a non xKu LNBF if you can.
Shaw Direct
Shaw Direct dish aiming problem
