Why did you take the case off of your 301?
gotta ask..why are the dishes not set to the proper skew?..Also, do yourself a very big favort and either cover those di plexers in soem sort of plastic, get them off the roof or coat the fittings( easiest and best) with a dilectric caulk.Get the caulk at any electrical supply house. It's not straight silicone and I would not reccomend using straight silicone.....You are asking for trouble leaving the dipleaxers and cable connections on the roof like that..Otherwise, your install looks good for a DIY....well today was the day. everything went as smoth as possible and i have everything working (ok littile issue w/ dish 500 feed but im not going to worry about that yet). the 622 looks AMAZING and im still getting used to how wonderful it is. Im posing the newest pics of the install and a few from before... not in a slide show this time (i didnt really like it).
please post any and all comments and have a wonderful night/ day.
thank you all again for all your help. oh and please dont tell me my room is a mess... I know it is and ill get around to it lol
http://s19.photobucket.com/albums/b156/case-a-kill/dish 622 install/
im taking your advice on the plastic cases (im going to lowes to pick up a water sprinkler case, heard those are good for the install)gotta ask..why are the dishes not set to the proper skew?..Also, do yourself a very big favor and either cover those diplexers in some sort of plastic, get them off the roof or coat the fittings( easiest and best) with a dielectric caulk.Get the caulk at any electrical supply house. It's not straight silicone and I would not recommend using straight silicone.....You are asking for trouble leaving the diplexers and cable connections on the roof like that..Otherwise, your install looks good for a DIY....
My main comment is how much air gap is there for the 622 on each side and does that cabinet have power ventilation, if not you will be able to fry and egg on the 622 after an hour or so. They run VERY hot, dangerously so.
Limited time offer
