Second try at installation failed | Page 2 | SatelliteGuys.US
It worked! Thanks so much Iceberg, knowing that the angle aligns with the center of the bolt made all the difference!
COOL!! :D
So what kind of sighnal are you pulling on some of those transponders?
If its low, you might have to nudge the dish a little bit. lean into the dish a little bit and see if the signal moves up :)
I'm getting about 85% in signal strength and between 70-80% in signal quality. Is that good?
DAMN Thats good :) (the quality is what you need to look at)
Is that on 12152 or 12117 (or another one)?
I would scroll through the transponders and make sure they all register pretty good (they should since you got 80 quality) and then do a blind scan and scan in the channels :)
Congrats on getting it working
That was on 12152.
I did a blind scan after I got the signal working and I think I'm getting all of the channels. There's a few scrambled channels which are labled "nagravision" "viacess" and "irdeto." I'm guessing this is normal?
general newbie question
Newbie Major Help????????
