SBC/DISH Subscribers - Status of 2Wire's MediaPortal | Page 2 | SatelliteGuys.US
"Most SOHO routers that I've seen only support one IP address for the WAN port. You could've changed the pool of IP address for DHCP to match the IP address given to you by SBC"
That is exactly what I did - and was told by one the 2wire - 3 tier tech, that they do not support it and my warranty would be null and void, if I use it for more than one IP.
They told me several times, that you can't turn off the firewall - yes I am aware of the fact, that you can configure the ports.
Furthermore the default setting of the 2wire homeportal is, that 2wire has access to your (!!!) modem.
I am sorry about my accent, it's pure german, I guess the distance might have mixed it up with a texan drawl.
Matt :D
dp 34
Screen saver on a 522
