Satellite problem | SatelliteGuys.US
Satellite problem
GarryzTopShop
3
Yerington Nevada
I have installed a new splitter in my motor home but only getting one singal out of it, I have a front and rear tvs, I am using two direct receivers, can anyone give me help with this,Garry
You'll have to be more clear to get any help. Did you install a splitter in the coax between the dish and the receiver(s)? Is there a dedicated coax for satellite built into your RV?
The OP says he has "two direct receivers", which I interpreted as being DirecTV receivers. Move this thread?
If you are saying that you have two receivers and you have added a splitter to the single cable to from the dish to feed them, you can't do that. Each receiver has to have it's own feed from the dish.
Reactions: brad1138 and KAB
If you only have 1 line from the dish, then you can only run 1 receiver (most likely, unless you have SWM / HD system, but I doubt it). You can not just split a sat signal. Occasionally it will work depending on the channels you are watching, but for the most part it won't.
Live DISH Press Event Coverage
HWS and 211K Billing DIRT Help?
