Claude Greiner said:Depends...
The thing I did not consider is that I just built a home with Radiant floor heating imbeded in concrete. No way in hell I can drill through the floor!
The new NEC discourages that - or exactly the reason you say.Dave nye said:Well most of this I agree with. I never go the same height as the wall outlets, I go higher or lower by a full plate. Most of the time the wire is run from outlet to outlet in a straight path. I just get through the drywall then push the bit to the outside wall I can tell if I have grabed a wire when I do that.
lostlife said:we've had a guy catch a mobile home on fire when he hit an electrical wire. i punch through the drywall, poke the bit through backwards and then move the fiberglass out of the way and make sure there is no other obstructions then put the bit back on my drill and drill through the outside wall.
Not true, as an ex journeyman electrician, the 12-2 14-2, or 14-3 ran inbetween outlets generally is ran 6 inches lower or higher( I always preferred lower) between the studs, you have to secure electrical with wire staples at 4" before entering the switch box. My suggestion is to always place them at the same height for safety purposes and aestheticsDave nye said:Well most of this I agree with. I never go the same height as the wall outlets, I go higher or lower by a full plate. Most of the time the wire is run from outlet to outlet in a straight path. I just get through the drywall then push the bit to the outside wall I can tell if I have grabed a wire when I do that.
mlb said:Here is a question for the pro's on here...
My basement has a sheet rock ceiling (previous owner put it in), therefore I have no easy access to the 2nd floor for my wiring. I do have air ducts that go from the basement to the 2nd floor, but the runs are very long (probably 40-50 feet, a turn in the duct when it gets to the rooms). How do you run the wiring in that kind of environment? Through the ducts, or along the outside of the house and drill through the external wall?
Thanks in advance for your help.
Limited time offer
