Replacement for Zinwell ZKF-F21N LNB for FTA Gallaxy 19 Reception | SatelliteGuys.US
stutzderryl
6
NM
Can anyone recommend a replacement for a Zinwell ZKF-F21N LNB? We have an old PANSAT dish used for Gallaxy 19 FTA Thai TV MPEG2 receiver. Thank for your help.
The GeoSatpro SL1PLL should work fine. It is also a great LNBF. You can get one from SatelliteAV, look at the top of the page for a link or you can also get them off of ebay.
Yea, the Zinwell is Standard with 10.75 LO.
So, the SatelliteAV PLL model is probably the best choice in North America.
The SatAV has had very favorable discussions here on the forum, too.
Thank you very much for your rapid response. I have one on order. Merry Christmas to all (Happy Holidays).
Your Welcome Stutz. You should have it in a couple of days. I think you will be pleased with the signal.
Newbie needs help....
TBS6925 now open source [Linux]
