Remote Control? | SatelliteGuys.US
Remote Control?
robert393
68
I just got a couple (2) 942 receivers (using in 2 seperate rooms in SINGLE mode)and one remote doesn't control my Denon AVR (volume is really all I need it to control!), and the other remote won't control my "sleep" timer.
Any suggestions on (high end) universal remotes? I'm vaguely familiar with the Pronto, but was really hoping for a NON-LCD based remote.
Thanks!
Robert
I'm only using 1-monitor per 942. I thought single mode would be the best configuration. What would be the advantages of running them in Dual mode?
DiShman1990 said:
Why are you using them in single mode?
This is what I thought when I connected in single-mode.
tawhite said:
Using one monitor per receiver, there is no advantage to dual mode. Single mode will give you PIP.
5 Orbital Positions Question
Life Expectancy of UG Antenna Cable
