Reed switch sensor actuator | Page 2 | SatelliteGuys.US
if you have the old sensor then i have the part that goes into it i bought offf ebay i think it was 10 for $5 shipped
i can upload pictures of the sensor when i get home
Okay so I got out there this morning and rolled up my sleeves at got to work. My actuator is made by a company named JGS btw, found the sticker when I took the rubber cap off. I found the sensor wires with on the bottom under the flat plastic casing. So, I proceeded to take the plastic bottom piece off. The screws were rusted and wouldn't move, even after spraying them with PB Blaster. I would turn the screw and the head of the screw would just strip away. So, I decided, I would just bust the plastic around the screw...I figured if the motor is bad I'll be buying another one anyway. Once I got inside I found the wires from the actuator and found that this whole time the ground of the sensor was orange, not black. Wow, I felt stupid. Once I wired it up with green and orange, it works perfectly. And this GBox is FAST!!!! So thanks for the help everyone! My system is working perfectly now!
Lost In Space
rtv on galaxy 19c
