record 2 shows ota only | SatelliteGuys.US
intowin
10
I am getting an over the air hd antenna. I want to be able to record two shows at the same time. Will not have sattelite or cable. Can this be done?
If so how.
Hd would be nice on both records but not mandatory.
Unfortunately, the Sony DHG-HDD250 and HDD500 is a single ATSC/QAM tuner system. In other words, you can only view/record one program at a time. This HD DVR comes with TVGOS, which works pretty well once you get it setup. However, Sony should be fire the engineers for not adding another 2-3 tuners.
http://www.avsforum.com/avs-vb/showthread.php?t=537711
Need some antenna HELP!
OTA Antenna Orientation ??
