Real problem getting Galaxy 10R | SatelliteGuys.US
JonStevo
64
With the new rig... 2100 rotor, 32", GREAT new LNB (thanks Pete!!)...2500A
Transponder 1 = 0 The rest I get from 60+
Then I do a blind scan... and it will hang (once it gets
the H/V info) at 5% (once) 10% twice and 12% once.
So I never get a complete scan....
Any ideas?
Jon
p.s. Some asked... Yes I am a Brit, in the US...... LOL
Jon, try nudging your dish away from E9 a little more.
My setup right now is a BUD actuator with the Vbox and G10R is very picky - the actuator has very fine resolution and I've noticed that I can get a much higher sig strength from a lot of xponders by nudging over a few more clicks.
(Another Limey here, the FTA section is full of us)
Yup... Get away from E9. I kept accidentally picking up that one too, E9 is a pretty strong one.
Thanks, I'll try that... I'm also thinking the new 1.5 lbs LNB
might have moved the dish, down, a little....
Got it!!!! The LNB had move the dish a little, a "tweek" up and all is fine!!!
Two LNBs on one dish and Clarke belt
Need help setting up Winegard 76cm w/sg2100 motor
