i know i need the SWM dish but, does HR34 come with on On Demand? and can i it without getting the whole - home - setup? thanks
Iceberg said:no you don't. I have just a HR34 and ethernet hooked directly to the receiver
He may have another receiver. I know they said you could hook up the cable to the 34 and be fine but that's being an issue now
jcrandall said:Could you expand on that being an issue, I hooked my HR34 up that way and eliminated the CCK and haven't noticed any problems (but don't want any to develop either).
Sometimes they start to disconnect from the other receivers like the other HDDVRS do when you connect a cat 5 cable to them. Not always but a lot of service calls in my area have been caused by this for some reason. I end up unhooking it and adding either a wifi deca or a broadband deca
lacubs said:can i asked why it take 2hr and 45minutes to install?
jcrandall said:OK, I have had times where it stops showing content from my other HR24s or vice versa. A reboot of the HR34 has always resolved it, I figured it is just software related - one of the many HR34 bugs that are lingering way too long in my opinion.
no, they have install the SWM, but it's one room only and i no basement all my dish stuff is outside my bedroom window on the roofDo you have SWM already? It's prolly going to be a plug in play if you do
only mine receiver on the accountIf there are any other receivers on the account everything gets changed over to SWM...and depending on how many receivers are on the account they may need a SWM16 The SWM8 splitter can support 8 tuners...you already got 5 with the HR34
lacubs said:no, they have install the SWM, but it's one room only and i no basement all my dish stuff is outside my bedroom window on the roof
It has already been established that there is only one receiver in the residence. Hutch1814 pretty much covered the whole install.If you have whole home you need a cck
Limited time offer
