Quick Question on the HR34 | SatelliteGuys.US
lacubs
1,596
42
Erie, Pa
i know i need the SWM dish but, does HR34 come with on On Demand? and can i it without getting the whole - home - setup? thanks
well, last Saturday i went to my first Casino and won $600, and today its gone! with my purchased of the HR34, they are coming Sunday so, tonight/tomorrow i will watch everything on my dvr
If you want on demand you are going to need the cinema connection kit. Which you might have to pay for. Ask the installer if he can hook you up with one
Iceberg said:
no you don't. I have just a HR34 and ethernet hooked directly to the receiver
He may have another receiver. I know they said you could hook up the cable to the 34 and be fine but that's being an issue now
Could you expand on that being an issue, I hooked my HR34 up that way and eliminated the CCK and haven't noticed any problems (but don't want any to develop either).
Sometimes they start to disconnect from the other receivers like the other HDDVRS do when you connect a cat 5 cable to them. Not always but a lot of service calls in my area have been caused by this for some reason. I end up unhooking it and adding either a wifi deca or a broadband deca
OK, I have had times where it stops showing content from my other HR24s or vice versa. A reboot of the HR34 has always resolved it, I figured it is just software related - one of the many HR34 bugs that are lingering way too long in my opinion.
I agree, the 34 has been out way too long and they haven't really done much to help the stability of it
Do you have SWM already? It's prolly going to be a plug in play if you do
no, they have install the SWM, but it's one room only and i no basement all my dish stuff is outside my bedroom window on the roof
If there are any other receivers on the account everything gets changed over to SWM...and depending on how many receivers are on the account they may need a SWM16
The SWM8 splitter can support 8 tuners...you already got 5 with the HR34
If there are any other receivers on the account everything gets changed over to SWM...and depending on how many receivers are on the account they may need a SWM16 The SWM8 splitter can support 8 tuners...you already got 5 with the HR34
only mine receiver on the account
Still should just be a matter of swapping the LNB and putting in a power inserter and being done
Note from DIRECTV on the DISH / AMC dispute
Comcast to DT ?
