Quick question about HD | SatelliteGuys.US
kanyon
6
I am thinking about getting Direct TV with HD, but I also need to keep my basic limited cable which is only like $12 a month to watch a couple of local channels that Direc Tv does not get. Is there a place on the HD box to hook up the cable?
Captain Spaulding said:
I don't believe you can connect your cable TV lline to the antenna in. You can connect the line to an external, over-the-air antenna though.
if you read the info from direct on the h20, it even says attenna or CABLE input.
HDMI & sound
Signup problems with DTV-help
