Questions about Blu-Ray Disk players | SatelliteGuys.US
piperut
SatelliteGuys Guru
137
Hi Everyone,
It appears that blu-ray might win out. So I am considering purchasing a blu-ray dvd player... but I have some questions.
The television I watch most things on is an Akai 55 inch rear projection TV.
I have a dvd player that upconverts the standard dvds to hd.
I also have a fair collection of dvd's. (I also have a dvd recorder, and many of these were recorded off the air...)
I do not want to be replacing all of my dvd's with blu-ray dvd's.
I have read that the new blu-ray and hd-dvd players will play the old dvd's.
The question I have about that -
Will the blu-ray dvd players upconvert the old dvd's to hd?
I realize a number of people have the dvr's from the satellite companies.
However, most of what I record is something I want to keep. The DVR's are limited by the size of the hard drive as to how much you can store. A dvd recorder, I am not limited by the size of the hard drive. I am only limited by how many disks I can purchase.
Are there any blu-ray dvd recorders (similar to the old vcr's)?
Also, I take a number of photos, and I put the photos on my computer, then add music, and make a dvd that will play on my dvd player. Are there any blu-ray dvd burners for the computer? How memory intensive is this?
Thanks,
roland
Blu-Ray players will upconvert over HDMI but not over component in most cases but if the tv allows upconverting over component it will
There are no set top blu ray recorders right now
There are PC blu-ray burners they run around $400 on ebay and newegg and about $500 for the dual layer ones. The 400 can burn up to 25gb and the 500 can burn 50gb. It uses the same pc memory as burning a regular cd but there have been compatibility issues with them reading in a BD-P.
This brings me back to why I was asking questions in the first place.
What do I gain by going to the new format dvd's (after the news this week, it appears that means blu-ray)?
If I am using a dvd player that does upconversion, is there really any picture quality gain by going to the new format?
Thanks,
roland
On a 55in RPTV it may not be as noticable as on a LCD or Plasma but it should be noticable. I know I have a 55" 720p LCD and the difference is night and day between DVD and Blu-Ray. While some movies have poor transfers others (like the pixar films) look 3d and have a picture that is unbelievable. There is a huge difference between upconvert and Blu-Ray (and I refused to beleive it as my Dish HD looks no better than upconverted dvd and thought BD/HD would be the same)
Years ago, I ended up caught in the BETA-VHS war. I had purchased the BETA vcr, and VHS won out. I had been waiting for the format war to settle on either Blu-Ray or HD-DVD. It appears that Blu-Ray is going to win out.
The other problems - no dvd recorder in blu-ray, or a workable dvd burner for the pc... those might have me holding off a bit longer. Also, I am thinking that most electronics, when they come out the price is high, and then the prices starts dropping.
Thanks,
roland
Thanks,
roland
How would not having a recorder or Blu-Ray drive affect your ability to buy a Blu-Ray player? It will play the recorded/burned DVD's you make just fine while you wait to buy BD recorders as they become cheaper.
And yes, there is a difference in PQ from either upconvert or broadcast HD by going to BD. How much of a difference will depend on your TV, but it will range from very noticable to stunning.
RE: Blu-ray recorders/burners.
Forget about them for at least a year. And when talking about 50GB media - even longer.
In terms of $/GB, hard drive storage is less than half as expensive. And likely will stay cheaper.
If you are comfortable with PCs, think about encoding/compressing movies.
You will have a hard time to differentiate between a 8GB 720p re-encode of a BD movie
from the original on anything but high-end 1080p TVs watching really close.
Diogen.
"Everything You Wanted to Know About Blu-ray-to-PSP Movie Transfers"
Wall-e
