Question on switch setup. | SatelliteGuys.US
rotor
14
Can someone please show me a schematic on how to hookup a dish 500 with a switch 21 with a 31 inch FTA dish with motor through a 4x1 switch all working through the pansat 2700a ? I want to keep the dish 500 setup and also the FTA 31 inch dish with motor working through the 4x1 switch. I am scared to do this without burning up my motor, switch 21, the 4x1 switch, and Pansat 2700a. Please, I need some help! :confused:
receiver-----motor----diseqc----lnb's
dont use the 21 switch unless you have a second receiver for Dish subscription
Ok, I just put a dish pro lnb on the dish 500 taking out the switch 21. My dish 500 is on the deck. The 31 inch dish is 150 foot from the deck. Will I still have to put the switch 4x1 between the LNB and motor? Jsut wondering how to keep the dish 500 hooked up to the pansat for 110 and 119. I want to use the 31 inch for other sats.
honestly the easiest thing to do is get a single or dual LNB (one that looks at one satellite) and hoseclamp it to the KU LNB. Much easier than running 150 feet of cable :)
Starchoice receiver
SBS6 ONN low today?
