Question about connecting 2 home distribution outputs together on 722's | Page 2 | SatelliteGuys.US
A good quality splitter will have RF isolation between outputs. So, if you hook your modulated channels into the splitter using the out ports, you should only get good video from the In port. Connecting the two back fed TVs to the Out ports of that four way splitter should create high isolation and those TVs would have bad pics. Unless it's a real cheapo splitter, those things even pass voltage when they're not intended to do so.
OP's best option is to connect the two Home Distro ports to a backwards two-way splitter. Then, from the In port, connect that wire to a separate splitter for whole house distribution. Total splitter loss is about 7db with (2) two-way splitters, not bad.
im aware of all that and forgive me if I simplified it too much.
We use what we are given - cheapo skywalker 1-in 2 out splitters. I have made them work SOMETIMES. Other times a powered amp distribution is the only fix. I know its physics and all but you cant deny the touch of black magic and the FORCING IT to work that can go into all of this.
Theres one thing I hate and thats being beat by a brainless machine.
NHL Network Woes
hd receivers
