Pvr 510 | SatelliteGuys.US
Pvr 510
mailman390
57
Connecticut
Will a PVR 510 receiver work on a Dish Pro system? Are these units any good? And will Dish activate a bought 510 or not like the 322?
I love my 510, it will work with a DP system. As long as the system isn't a lease they will activate it. Just get the R00 and S00 number and call Dish to see if its a lease and if there is a balance on it.
A 510 will work with a DishPro or Legacy system. It is the legacy receivers that need the adaptor unless you have a DPP44 switch.
Are you AEP?
If you're an AEP subscriber, you'll be able to provision it with no problem and no extra cost except for the normal receiver fee. If you're not, you'll have to pay an additional $4.98 per month on top of the receiver fee for the bs VOD fee.
I want a HD DVR!
PIP question
