problem with some TPs on 61.5 in NY | SatelliteGuys.US
NEOSG
168
East Amherst, NY
Losing signal on some TPs on 61.5 in NY.
Some I tested were
TP2 - OK
TP 9 - OK
TP 13 - OK
TP 18 - OK
TP 19 - OK
TP 24 - OK
TP22 & 30 - not OK really weak signal
ran check switch , all OK. Seeing same thing on 2x211s
Any suggestions on other testing or troubleshooting?
Can anyone else check and report their findings. Channel to test would be some of the NHL HD channels 9551 has a game tonight.
Thanks in advance.
EDIT: Getting lock on 22 and 30 , but signal much weaker than other TPs
What signal strength are you getting on the OK TP's.
Your dish may be slightly misaligned.
When I had 61.5 all TP were solid.
Thanks for the ideas. I am guessing if the weather is a factor, I'll see a flare up again after this weekends storm.
I didn't have any problems with 61.5 last night, just crappy sd feeds on my hdtv from the nhl ci package. Thank god for the hdnet and pit fsn hd feeds of the pitt/sens game.
Maybe your dish was loaded with ice and snow.
VIP222 update L.303
722 Noise Hard drive at Night?
