Just a guess, but I would think the rain-fade problem comes from rain between the dish and the satellite, and what hits the dish is minimal. Rain usually comes from the south around here, I've seen the signal drop or go out when no rain is falling yet at my dishes. Maybe the shield helps some though.
The lens shade is a very good idea. While heavy rain or thick cloud cover can result in a loss of signal, severe attenuation (with the least amount of water) is caused by water sheeting across the lens of the feedhorn.
An example of a product developed to lessen the affect of water collecting on a surface is Rain Shield. Rain Shield was developed for reducing the rain sheeting problems with mobile satellite dishes. Mobile domes have a problem with even light rain standing or sheeting on the dome of the system attenuating and often eliminating the satellite signals resulting in loss of signal.
We have participated in tests where controlled amounts of water were sprayed onto the lens of an LNBF. The quality readings were consistently higher using a LNBF with Rain Shield applied.
... small holes in a semi-arc at the top of the plastic covering the horn throat...
TVROPro, that is the same feedhorn cover that is on my 1M Channel Master. There are a series of small holes in a semi-arc at the top of the plastic covering the horn throat. The dish gets very acceptable results during most rainstorms![]()
Important feature because condensation will form without some ventilation. Not a good idea at all to seal the thing up airtight.
In the early days (opps here he goes again), before Corotors, I made a pyramid shaped feed horn flanged to the LNA (the LNA was rotated with an over-the-air antenna rotor for horiz. and vert. transponders). At times, it would become overcome with sparklies that I couldn't explain. Finally noticed about a half teaspoon of condensation inside the lens. Spaced the lense to create a gap and never had a problem after that. This was way before Ku.
Harold
I have used a clear 20oz plastic Coke bottle before when I had them break on my Primestar dishes. The center of the bottle is about the same diameter, it is clear plastic, and fits pretty well.
You can cut it with scissors, and then put on a little plastic glue and a rubber band overnight, and it is there forever.
Fred
Hey tvropro,
What I was referring to was the hood.
The clear plastic will not interfere with the incoming signal. For one thing, the LNBf is more than likely lower than the signal stream, and the other thing is that what it does get in the way of, will pass through.
Fred
Make sure that the shield doesn't block any of the reflector view from the feedhorn. If water, snow or contaminants sit on top of the shield, the RF passive material will become a RF block.
To test if the shield is blocking, cover the shield with foil. If the signal and or quality drops, trim the hood back and retest.
An application of Rain Shield to the lens of the LNBF twice a year will also solve the problem.
Limited time offer
