ppv enable on all receivers | SatelliteGuys.US
bighick
103
Omaha, Ne
Sorry I haven't ordered a PPV for a while and can not remember if it is enabled on both of my receivers or not. It will be a football game, I just need to know if i need to run a quick cable to my other tv or if it will be enabled on all both of my dual tuner receivers.
It won't be automatically enabled BUT order it on one receiver, then the other and you'll only be charged once. Same PPV, same time of course. I don't do many PPVs either but when I do I order from both receivers. Always been charged ONCE. I believe it even says as much in the manual. I wouldn't try this for VOD though.
Ed
From my 722 manual, page 36:
"After you buy a Pay-Per-View program you can view it on all receivers on your Dish Network account. Using your remote control, you can order the same program for each receiver but you pay for the program only ONCE"
I've done just that several times. Never incurred more than the single charge. Hope this helps.:)
Ed
DVR 625 Forcing Anamorphic
What happened to college gameday?
