PLEASE GO BACK TO SD | Page 2 | SatelliteGuys.US
But just because they are channel numbers 2-6 doesn't mean that they are VHF. I receive a UHF channel 2.1 from Atlanta that has excellent reception.
Your guide is probably using the PSIP channel info to remap your UHF channel down to it's VHF number. WSB-DT seems to be on UHF channel 39.
All TV channels from 2-13 fall in the VHF frequency range. 2-6 are classified as Low VHF (54-88MHz), and 7-13 are classified as High VHF (174-216MHz). UHF starts at 300MHz.
Ok, you wanna be technical, I'm referring to the frequencies assigned analog channels 2-6. Yep, Channel 2.1 could be transmitted on the frequency previously known as channel 41, for example. And the channel known as 13 could be transmitted on the frequency previously used by analog channel 2.
The point is, the low VHF band is not a good choice for digital TV. In fact, at one point, we had a channel 1, but it was abandoned/repurposed as it was simply too awful for TV transmissions, according to some sources. Other sources don't mention reception concerns, just a need to repurpose the spectrum.
Gottcha. Never knew that. It is interesting because when I do a regular scan with no converter box (just the TV itself) it also comes up as 002-01. So I guess the TV automatically does the mapdown too. Cool!
2-6 shouldn't have been used for DTV, they weren't good enough for analog either. Maybe if they were allowed significantly more power they would be better.
Well after the full-power non-repeater analog stations go dark in 2/09, there will be quite a bit of DTV on the VHF band - much of it presumably on channels 2-6.
In 1940, the FCC reassigned the 44–50 MHz area of the frequency range from television to the FM broadcast band, where it remained until being moved to its current location in 1946. Television's channel 1 frequency range was moved to 50–56 MHz.
The first post-World War II telecommunications conferences formally allocated TV frequencies in 1945–1946. In 1947, the FCC decided to reserve channel 1 for lower-power community television stations, and moved existing channel 1 stations to higher frequencies. Community stations covered smaller cities and were allowed less radiated power.
From 1945 to 1948 TV stations in the U.S. shared Channel 1 and other channels with fixed and mobile services. The FCC decided in 1948 that a primary (non-shared) allocation of the VHF radio spectrum was needed for television broadcasting.
The FCC in May 1948 formally changed the rules on TV band allocations based on propagation knowledge gained during the era of shared-user allocations. The 44-50MHz band used by Channel 1 was replaced by lower-power narrowband users.
Channel 1 was reassigned to fixed and mobile services (44-50 MHz) in order to end their former shared use of other VHF TV frequencies. Rather than renumber the TV channel table, it was decided to merely remove Channel 1 from the table.
The above came from Wikipedia but matches other things I've read at various times in the past 30 years. I've also read that public service agencies (IOW police) that had shared the radio waves with broadcast television were having problems with interference. Also, logically enough, more than a few television stations reported getting interference from the public service agencies' radios.
It's been long enough that my memory is fuzzy, but I think there was something about taxi companies' radios being in the same boat.
In short, the problem wasn't that the frequency range assigned to television channel one were unsuitable for the purpose, but that the spectrum was at the time a shared one - and becoming more crowded as time wore on. That chunk of the spectrum just happened to be the one that was reassigned for other uses (and the "other uses" were then moved out of the rest of the frequencies being used for broadcast television).
When ATSC was being defined, stations insisted that their investment in their identities be preserved. "News 4" wanted to be "News 4" forever, regardless of what actual frequency they transmitted on. So it was built in to the system that you could tune in channel 4, and it would be found, and displayed as channel 4, even if it was transmitting on the frequency previously called channel 18. PSIP supports this.
All ATSC tuners are supposed to support this, although I gather there have been a couple that don't do it well, or at all.
New satellite launches despite economic turbulence ?
Connecting Dish 322 to PC TV tuner
