So My playlist won't hold the sort of A-Z or anything else beside by date earliest to latest recordings. I have an external 1.5 TB drive hooked up to the box. Has anyone else had this problem?
Trevor
Go Fins!
Hmm, 20-100's is all I have. One thing of note, all the directv receivers have the 'keep last playlist sort' as an available option out of the box. Only the 20-100 requires you to to the 'iamanedgecutter', which enables the option in the miscellaneous menu. Always thought that was odd.
maybe I should have them send me a new box since this feature will not work. I won't lose my programs because I have an external drive running on the box
Trevor
Programming on external disk drives is tied to the receiver. You can attach the drive to a replacement receiver and you'll see the playlist, but be unable to play any of the recordings.
However...they'll probably fix it. It was broken in the prior CE, fixed a few CE releases later, and then rebroken in the NR. Theres no rush to market to get the next NR out, so perhaps they'll actually take the time to fix all the known problems before they fire it out.
Limited time offer
