Play in motor? | Page 2 | SatelliteGuys.US
Play in motor?
Dish Arc Adjustment
Found it! Hope this may help you.
To see if that dish is warped, do the two string test: one string hortizonal (centered at dish) and the other verticle (centered at the dish). If the strings at the center of the dish doesn't touch, the dish is warped.
The info is awesome! I had been thinking about moving my setup to a better location.....this just might make me do it. I am toying with several options at the moment :)
Thanks MrFTAMan for the information and files!
You're welcome, Tron!
I've been thinking... :book:
Maybe Iceberg and the moderators ought to create a new section on this forum about satellite installation. It is strictly about installing satellite systems, C Band, Ku Band, 4DTV... with charts, drawings, diagrams.
Just have a section for FTA and satellite hobbists to go to and learn how to install any thing from line of sight finding, setting and plumbing a pole to finetuning a dish. Members can donate info on anything about installation, with approval from our modulators.
Just a reference section, nothing else!
If someone in the regular forum posting about having problems with their system, then somebody can suggest to go to the "Installation" section.
Recently a 4DTV section was created with huge success! :D
Just a thought...
Recently I came across a site that mentions about planting a pole for a satellite system and how much cement to use. I will be looking for that info and post it (soon).
THanks to all for the advice! I seem to have things back in order. Here is what I did - not sure if it was one thing or several that was causing problems:
I but my old 80cm Fortec back up. Put the old Fortec Universal LNB back on. Peaked the dish at my true south satellite. Did a factory reset on my receiver. Adjusted/tightened up the backlash on the motor.
I now get all satellites and am getting everything with good signal quality. I even have some hot tp's in the 80's on several birds :)
I do still have one problem. RTN - I just can't get a lock on it. I get the NBC bars just a booming in, but no go on RTN. At least I can get RTN OTA.
So, No I need to see if my 90cm is warped, and replace the broken bolts. THen I will set it up and attempt to get RTN. THANKS again!
sat 123 w
Where did the remote go?
